Ged the mail i recieved today from AP.ged wrote:Cheers for that info Tony. I'll file it away for future use.
CP2394-60 pressure plate in the Ø9.5" uprated special tuning range is rated to 350lbft torque.
The next option as a direct replacement to the -60 is:-
CP2394-46 rated to 522lbft torque.
We would recommend using a paddle plate with this unit because an organic plate can cause clutch drag. Also note that the Ø9.5" spring centre driven plates have a torque capacity on the spring centre of 350lbft, so if the installation has more power than that it is recommended that a rigid centre plate is used.
However this set up of high clamp cover and rigid centre cerametalic driven plate would be considered harsh for road applications!
Current driven plate
CP2346-4 organic / spring centre driven plate (1"x23T spline)
Alternative
CP4216-4 6 paddle / spring centre driven plate (1"x23T spline)
Alternative
CP4196-5 6 paddle / rigid centre driven plate (1"x23T spline)
Dave how much was the helix? is it a 9.5 or 10.5 clutch?
