flapper running rich
toughy V8
Post by toughy V8 »
my bmw is finally running, but it runs extremely rich and wont tickover properly could my air flow meter be knackered?
katanaman
Post by katanaman »
Is the coolant temp sensor ok? Try disconnecting the cold start injector if you have one.
toughy V8
Post by toughy V8 »
ive disconnected the cold start injector made no difference, which one is the coolant temp sensor,
Just behind the distributor, there's two connectors, a brown one and a white one. It's one of those.....
Has anybody scanned in the Land Rover fault-finding guide for the flapper system yet?
demo2
Moderator Gold
Moderator Gold
Post by demo2 »
The coolant is the white senser :D
landybob_v8
Post by landybob_v8 »
the one behind the easy one
v8's everywhere at least the one in the spare bedrooms gone now
mrs happy again
Lewis
Post by Lewis »
I have a similar problem, I think - runs rich, slightly more sooty exhaust than I expected.
Also - it has this intermittent idle fault - it hunts from say 350 to 750rpm when warm/hot, whereas at cold it stays rock steady at 800rpm. This hunting also causes it to stall when i come off the throttle hard, or am coming down the gears to a junction and slowing.
Other times and on the move, it's fine. Sometimes even when hot, irritatingly :lol:
Is that the butterfly or something else?
Very frustrating but does seem primarily related to engine bay heat so going to put one fan on permanantly and get some vents in.
This doc:
http://www.cowdery.org.uk/downloads/V8EFiSystem.pdf
(borrowed from somewhere) has a full diagnosis for the flapper system. If you find the bit to check the coolant sensor, you do it from the ECU connector (to also check out the wiring / connectors), that should help.
