Could i have i damaged my engine?
Started up my rv8 4.6 today to show a friend and after a couple of mins at idle i revved it a couple of times to hear the lovely sound of the engine revving.
Unfortunately i had a spanner near the throttle linkage which jammed the throttle on full, after a couple seconds of panic i turned the engine of.
It was running at full revs for about 5/6 secs, is this bad?
The engine has done about 500 miles.
It sounds ok im just a little paranoid that i may have done something.
Your thoughts are appreciated.
Chris
Chris
I wouldnt worry. Its no different form caning it for a few seconds on the road is it ??
What efi system are you using?
I was advised by a dyno owner the Hotwire has a rev limiter at 6750
Mine does but it;s not that standard!DaveEFI wrote:Don't think any standard RV8 will get anywhere near 6750 rpm.Ian Anderson wrote:What efi system are you using?
need4speed
- Getting There
Sorry but i disagree with you there. Its far more damaging for an engine to be held at 6500rpm for a while in neutral than it is revving at the same revs under load, ie driving in gear....mgbv8 wrote:I wouldnt worry. Its no different form caning it for a few seconds on the road is it ??
That being said, given the length of time the engine was revving, i think it will be ok.
Wouldn't worry myself I doubt you have taken 10 minutes off it's life. Have you ever tried to rev an engine to death
? you would be amazed how long it takes! The engine in question was in a Tolbert Solaira, full throttle in neutral about 15 minutes as far as I remember, it acatually siezed from over heating rather than going bang, my mate who owned the thing was most dissapointed, teach it to fail it's MOT for being a rust bucket.
need4speed wrote:Sorry but i disagree with you there. Its far more damaging for an engine to be held at 6500rpm for a while in neutral than it is revving at the same revs under load, ie driving in gear....mgbv8 wrote:I wouldnt worry. Its no different form caning it for a few seconds on the road is it ??
You disagree and then agree ???
I see your point though
I accidentally revved my 3500c to over 8000 for a few seconds once. It survived !!
And its had a few good sessione recently when its hit the 7000 + mark as traction has been lost.
We did a similar thing many years ago when I was doing my City & Guilds. The college had been given an MOT failure MK1 Fiesta 1.1, we jammed the throttle open and started it up, after 15 minutes we went for a tea break, when we got back it was still running. Our instructor knocked a screwdriver into the bottom corner of the sump to drain the oil out (pre-H&Skiwicar wrote:Wouldn't worry myself I doubt you have taken 10 minutes off it's life. Have you ever tried to rev an engine to death![]()
Land Rover SIIA 88" fitted with a 180BHP V8
Some is good, more is better, and too much is just enough!!
Hi Smudge
I like your style alot
I think the solaira engine might already have been on it's way out as it had been used to see how fast we could get it to go in second gear. We sort of met a platau at about 55 from what I remember, couldn't get it to rev any faster due to valve bounce. That was until said owner came in one day and said "I got 83 in second", after the storm od disbelief settled down he explained how. . . Bottom of the M3 he got the car up to 85 in top (on the speedo) down hill keeping the throttle jammed open with one foot he declutched, slammed it into second and dumped the clutch, reconed he was still doing 83 when he got the clutch out! ! !
though he did admit that from the tyre smoke the wheels might not have been turning that fast.
Will Reeve
- Getting There
