no spark
it will either be a ceramic looking thing attached to the coil or it will just simply be a wire in the loom. I don't think it will be a blown resistor as you have a spark when you aren't cranking. It could very well be you don't have a feed from the switched side of the starter to the coil though. Are you using a 9v coil? If not then you shouldn't have a resistor in there anyway and you can bridge the + on the coil direct to a known good ign 12v supply. If you are on a 9v coil then simply connect a wire direct from switched side of starter (the cable going into the motor itself) to the + on the coil.
I would say that this is caused by a broken wire or something from the starter as marki says (or a lack of a wire). Don't understand your last post, but the then i've had a few????
If you have a ballast resistor and a 9V coil, you should have 2 wires to your coil +ve. One should be from the ignition circult via the ballast resistor, the other directly from the starter. I think the theory is so that the 9V coil has a 12+V kick start when you first turn over to help it start from cold
There shouldn't be a ballast resistor on the ignition system from a Range Rover EFi.
The ignition system is separate from the injection system; they are only linked by a feed from the coil to the ECU to tell the ECU when the engine is rotating.
The wiring is dead simple - there should be a white feed wire from IGN+ to the coil and ignition amp. Then there should be a white/black wire from the amp back to the coil and also to the ECU and tacho.
The white/red wire is the crank signal from the ignition switch to the starter and to the ECU.
