v8 mini clubman van
v8mini1
v8 mini clubman van
Post by v8mini1 »
hi guys heres our mini van with a 3.9 v8 stage 3 heads and a 500 cfm edelbrock on her, took roughly 7months to build and had its first run down santa pod sunday at the mini show to test it,
Will Reeve
Post by Will Reeve »
stunning....are you sure you have a big enough radiator in there!
v8mini1
Post by v8mini1 »
well those pesky v8's are hard to keep kool lol
v8trev
Post by v8trev »
Nice -which front crossmember/ suspension set up you used there?
v8mini1 wrote:well those pesky v8's are hard to keep kool lol
audi 5cyl ally rad half the size of yours and keeps my 4.6 well cool ;-)
andyv8van
Post by andyv8van »
Great stuff, Another V8 in a mini.
I have used a standard SD1 size rad with twin cooling fans with no issues, got 65mm wide radiator in now , same frontal area size.Went bigger with getting the supercharger , so it will always keep it cool , even in traffic.
How did you go at santa pod?, was at show in my daily, its not the same :(
What set up are you using for the Suspension , axle , etc
regards
Andy
3.9 V8 Mini Van....THE BEAST
v8mini1
Post by v8mini1 »
hey all, its a triumph herald front end and suspension and a mgb gt rear axle santa pod went not bad did a 15.1 "92mph but the dif blew half way up. so got another and its gnna be tested.
