RV8 engine confused about a connection.
A is the back of the water pump which is where the leak is from coming out of the hole. I thought this was just part of the casting and was closed.
B is the stub outlet off the water pump (pre-serpentine)
C is the Stat housing.
Have I piped it correctly? if so does A need blanking off? and if so with what do you reccomend as a blank?
