Am I Pushing It Now?
with the new upgrades planned for the next few weeks,
am i pushing my injectors past the limit now???
i'll have to get some one sat in with the laptop as bit hard giving her large and looking at laptop screen
fuel pressure is 45psi
i should of expected a reply from you like that P
nice one Ian
what injectors are you using out of curiosity mate.
What injectors are you using Tony ?
Dont forget....you could easily wind the 044 to 80+psi.
Im using a little over 80psi at peak.
Although some injectors work better than others at higher pressures.
if increasing FP, do make sure all fuel lines are capable of withstanding the pressure.
hi stevie, good to hear from you again,
im using the stock 3.9 hotwire injectors mate,
i could be wrong, but 180-188cc rings a bell
That sounds pretty small !!!!
An LS1 uses circa 270cc and they will do say 400-450 at a push ( albeit at 63psi )
The handiest new upgrade for you would be a set of green bosch ( Ford SVO ) 42 lb injectors.
They will be good for 500+, and cheap as chips on ebay these days.
some one on the old forum had a set of 8 cossie injectors,
buggered if i can remember who now,
ok i'll keep an eye out mate,
If any one finds them on ebay before post the link here please.
Cossie injectors are low impedance, and still pretty small.
I think they are only like 280cc standard. Even the Cossie greens, are still fairly small at only 380cc.
Can the VEMS run low impedance injectors ?
http://motors.search.ebay.com/search/se ... p=1&fsoo=1
In the US obviously.
or check out www.racetronix.com
