Exhaust manifold locking plates...needed?
Will Reeve
- Getting There
My old engine had fold over locking plates on the exhaust manifold bolts, sort of wind-out protection...are they really necessary? Has it been known for the exhaust manifold bolts to vibrate themselves out?
My mates Land Rover 101FC has locking plates on the exhaust manifold bolts, but the manifolds are fitted without gaskets. I used standard bolts and spring washers along with gaskets, as per SD1, and have never had a problem with the manifold bolts coming loose.
Land Rover SIIA 88" fitted with a 180BHP V8
Some is good, more is better, and too much is just enough!!
Will Reeve
- Getting There
They're a Land Rover item, my mate got his from our local Land Rover specialist (John Craddocks), they were only a few pence each IIRC. My manifold bolts have never loosened using just bolts and spring washers, although I doubt the spring effect lasts long due to the heat off the manifold.
The exhaust manifold locking plates were also fitted as standard to the V8 engines in the Rover 3500 P6B from circa 1968 till 1976. Land Rover was building all Rover V8 engines from 1972 onwards, so they likely appeared on all around that time.
I retain the P6 manifolds on my 4.6, fitted as per original without gaskets and with split washers beneath the bolt heads, they would nearly all work loose in a very short space of time, so at least weekly I had to nip one or more up.
I replaced this arrangement with a set of OEM locking plates that I purchased from a P6 specialsit some years ago, fitted them and no more loose bolts...
Ron.
Ron.
4.6 Rover 3500 P6B
Re: Exhaust manifold locking plates...needed?
I use 3Ms Scotch-Clad 776 on every thread that goes into ally on these engines.Will Reeve wrote:My old engine had fold over locking plates on the exhaust manifold bolts, sort of wind-out protection...are they really necessary? Has it been known for the exhaust manifold bolts to vibrate themselves out?
It has three functions:-
Prevents corrosion.
Locks the fixing
Seals the tread.
Strangely it was specified for early engines which also had the locking plates for the manifolds, but seemed to disappear off the horizon on later ones.
It costs about 30 quid for a 1 litre tin and can be hard to find, but works perfectly. No more broken water pump and thermostat bolts.
