Exhaust Manifold Gaskets,
Any one know where to get these gaskets from????
Im running a set at the moment, but when i change the heads i want to replace the gaskets, (ones in the picture i have been loaned)
Im going to open up the exhaust ports to match the gaskets also once i have a set.
the only ones i have found so far are these, which i have been told are catalic ones
r2d2hp
Post by r2d2hp »
V8Dev sell them Tony
the top ones reg???
r2d2hp
Post by r2d2hp »
Yes mate, Am sure thats who I purchased mine from.
katanaman
Post by katanaman »
Looks like RPI does them too, they have a set on fleebay but they include studs and nuts. Probably do gaskets on their own tho. Have you tried Jim? That's who you got your last set from wasn't it?
yes i did Marki,
but when i contacted Jim last year he said he could no longer get them :cry:
GreenV8S
Post by GreenV8S »
The ones you're after look like the twin metal composite ones I get from RPI.
Peter Humphries (and a green V8S)
you got a picture Pete?
Post by ian.stewart »
POP BROWNS do over size single gaskets if anyone is intrested.
THE SMOKING GNU
IainB
Post by IainB »
Dont Real Steel also do these, sure Ive seen them / purchased them from there (albeit a LONG time ago!)
GreenV8S
Post by GreenV8S »
thev8kid wrote:you got a picture Pete?
"Here's one I prepared earlier".
The port dimensions are 26mm wide 37.5mm high. The ones I've bought previously aren't as chunky as these but the port dimensions are the same. You can't see it from the picture, but they're about 2mm thick and consist of a fibrous matrix with a wire mesh through the middle of it.
ah yeah seen them before,
im trying to locate the ones that i have in the pictures, as these seem to be the best ones i have used for sealing so far.
the topmost ones look very oem. they may be from the later 4.6 engines.
Eliot wrote:the topmost ones look very oem. they may be from the later 4.6 engines.
correct,
but nobody seems to stock them now, just the ones like greenv8s posted
GreenV8S
Post by GreenV8S »
thev8kid wrote:ah yeah seen them before,
Sorry those aren't what you want.
By chance I came across this advert recently which looks very similar to the ones you asked about:
http://www.clever-trevor.net/part/43/ex ... s0091.html
I haven't seen these in the flesh though.
