Best exhaust diameter, 3.9 off road trialler
V8James
Post by V8James »
Hi all
Got to build a new exhaust system for my triller, system that was on it was quite nasty but worked so i left it but the tin work has eaten it beyond repair
Its got a 3.9 in it + will have boxer 4 su setup
Any one suggest best exhaust diameter for primaries + after it joins to 1?
I was thinking 1.75" then 2.5 or 3"
Cheers all
James
HairbearTE
Post by HairbearTE »
1.75" primaries will support a 600hp small block chevy. You will lose torque if you go that way. 1.5" would be fine for your engine, 1.625" would work ok, but still plenty big enough for your combo on paper.
Hi For my 2p worth I would say for an off road trailer you don't want to go above 1.5"primary, otherwise you will loose bottom end and gain nothing up top because the cam will be selected for power off idle.
ramon alban
Post by ramon alban »
Hello James, Not being negative, but I simply dont know the dimensional answer to your question, but, despite many ideas about sizing, usually the primary pipe size is related to exhaust valve and port size.
Just think of it as trying to provide the smoothest possible exit route for the hot gasses with either, nil, or only smooth changes of outlet/primary pipe cross section. Indeed, the sort of arrangement achieved in most if not all cast iron manifolds. :shock:
Choosing pipe size then, may be just one of a number of issues, but it is also determined by collector arrangement, available materials and space around the engine and beyond. There is also the reasonable conclusion that as the pipes merge then they also need to grow in diameter to cope with the accumulating volumes of exhaust gas at each junction.
But what about length? Primary pipe length is dependent on wave tuning. Typically, longer pipes tune for lower rpm power and shorter pipes favour higher rpm power. So, use determines best length.
And what of the other considerations. Types of silencer will affect performance as will the thickness and type of all materials used (headers/pipes/silencers). For best performance, the thicker the better, because this keeps the exhaust gasses hotter, so less dense, requiring less energy to move them along. Or, inversely, colder gasses are denser, heavier and require more effort to keep them moving. (anyone voting to bring back cast iron manifolds at the election? 8-) )
Silencer type? Absorbsion (simplest), restriction (worst/cheapest) or relection (sophisticated), pretty much self explanitory, but each having a different effect on the way gasses move thro the system. Difficult choices when one knows the differences.
On the other hand do we just choose silencers by whats on the garage floor or what one can get from auto jumbles or Ebay.
If the above choices seem fatuous, they definitely are not, because they do make a difference to efficiency, which sorta makes worrying only about primary pipe diameter whilst ignoring everything else, slightly incidental.
Especially as my first observation is probably the best bet for primary pipe size.
You can read much, much more about this whole subject in my PDF on exhaust systems available from this link:
http://www.vintagemodelairplane.com/pag ... ust01.html
V8James
Post by V8James »
Cheers all for the replies
Ill use the cast manifolds onto 1.5" then when join going upto 2.5"
ramon - cheers, i didnt even think about the silencers
Ill be trying to use a fairly decent thinkness pipe as being used off road it will help with damage etc, although only slightly its got to help
Problem i have is that because its only an 80" wheelbase with series 1 body i dont realy know what to do about pipe length before i join the 2 together
I know its abit of an open question but any suggestions to primary length?
Ill only have the 1 silencer due to space + that will have to be mounted at the back
Cheers for the help guys
James
simontwithers
Post by simontwithers »
I have sent you a message (pm),
regards
Simon
topcatcustom
Post by topcatcustom »
I'd have thought you would be better off with 4-2-1 manifolds each side rather than 4-1, should be better for pulling power as (as stated before) you wont need top end. 1.1/2" primaries, 1.3/4" secondaries and 2" collectors Y'd together to a 2.3/4" main may work well?
TC
