When I try to bleed it the fluid is not returning to the master cylinder properly. This means repeated pressing the pedal just pumps more fluid to the slave and blows the o-rings.
Is there a proper way to set up a master cyl pushrod? Adjusting it to the max in either direction seems to have more or less the same result.
The master is a Girling integral reservoir item, I found this site that describes how they work (under the heading Non-residual Pressure Master Cylinder (Girling)): http://www.the-crankshaft.info/2009/09/ ... ystem.html
Could the internal valve in the master be playing up? Meaning the inlet port opens too early and therefore fluid is pulled from the reservoir instead of the slave when the pedal comes back up?
Should I have -3 or -4 lines to the slave? Does that really matter?
I'm using a .7" bore master with a Saab concentric slave and -3 lines.
Any ideas appreciated as always.
thanks
