Cleaning black sludge from block
Quagmire
Post by Quagmire »
Another vote for Fairy Power spray here! Used it on my heads etc when rebuilding my 3.5...
Degrease with Paraffin, dry
Power Spray, work in with a stiff brush
Hose and pressure wash off
Stick in dish washer!
:D :D :D
1974 Rover 3500s
1984 3.5 90
1959 2.25 series 2
Muscle-Manta
Post by Muscle-Manta »
Try Nitromors paint stripper its amazing! I cleaned a set of very dirty rocker gear in it. It removed all trace of black deposit as well as the brown varnish stain on some of the rockers. I washed the parts in diesel afterwords, however hot water might do the trick.
HughN
Post by HughN »
I think I need to divide the block into eight different areas and use a different cleaning technique on each one!
At least no-one suggested Cillit Bang!
"At least no-one suggested Cillit Bang!"
tried it on an A series block, it was rubbish! too much effort, straight steel wool worked better! :lol:
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
I tried Nitroglycerine
Sparked it up and BANG THE BLOCK WAS GONE :lol:
gelmonkey
Post by gelmonkey »
Muscle-Manta wrote:Try Nitromors paint stripper its amazing! I cleaned a set of very dirty rocker gear in it. It removed all trace of black deposit as well as the brown varnish stain on some of the rockers. I washed the parts in diesel afterwords, however hot water might do the trick.
Told you he was from Thatcham :lol:
Oven cleaner,
and when mums not home i pop over to my parents house and use the dishwasher :lol:
seight
Post by seight »
mgbv8 wrote:So its not just me thats been busted by the missus as she found engine parts in the dishwasher then :)
Came home the other day to find my wife wrestling with the dish washer, saying something about needing a new one as it "seems to be on it's way out". I suddenly had a sinking feeling and had to do some quick thinking. The day before, while she was out, I used it to clean 4 rocker covers that I'd just had bead blasted :lol:
HughN
Post by HughN »
On closer inspection itlooks like the front of the oil galleries are plugged-off with three strike marks peening each plug in position. Removing these (and finding replacements) might be as much effort as getting the block out of the car!
HughN
Post by HughN »
I've just tried it on the inside of the timing cover :shock:. It looks like new!
Thanks for that top-tip!
