http://www.v8forum.co.uk/forum/viewtopic.php?t=6696
I have a procharger C1. I'm planning on fitting it to my re-built 4.6 rover V8. I've been doing some calcs (below) on my supercharger and trying to compare it to some similar Rotrex ones.
(edited)
Procharger don't publish compressor maps. They just state max air flow and pressure, supercharger max supported HP and base range of engine HP before supercharging.
My 4.6 falls fine into these figures, BUT no where do Procharger mention engine capacity/ efficiencies?. Reading through the Garrett website, it says capacity is an important factor in sizing the compressor.
e.g. It states a 2L 4cyl and a 5Lv8 both trying to achieve 400bhp would need the same mass of air but would need different compressors to achieve this. could this be applicable to supercharging?
I'm wondering how/if I can compare the procharger C1 to other compressors where compressor maps are published? Procharger publish inducer and exducer diameters. Would it be enough to roughly size the compressor using these parameters rather relying on their "marketing" blurb?
The C1 has a compressor exducer dia of 107.95mm. This seems much bigger than most turbos. It has an inducer dia of 69.75mm. The trim works out to 41.87 which seems quite low compared to turbos. It has a max rpm of 80,000 which seems quite high for a supercharger.
Really just trying to estimate if this supercharger is suitable for my 4.6. Aiming for 400bhp?
All help/ thoughts much appriciated.
