wiper motor on a tube frame car
General Chat About Body & Strengthening
JJMclure
Post by JJMclure »
Has anyone got any pics of front windscreen wiper motor set up on a tube chassis street car? just looking for some ideas at this stage...
don't nibble on the barrel, pull the trigger!
Magnetteman
Post by Magnetteman »
I'm not sure this is what you're after but I had similar issues so I used a single wiper on a direct drive motor and mounted it on the roof panel just behind the cage cross bar at the top of the windscreen...
http://www.s-v-c.co.uk/prod_wipers.html
Gives a pretty good schematic
Paul B
Post by Paul B »
I'm not quite sure why being tube framed should present any problems, but here's mine, sort of tube framed. :D
Motor/spindles are Range Rover, as I wanted real wipers, that worked, with a full sweep and real blades etc. I can shorten the connecting pipes to suit, flare the ends with a brake pipe flare tool. It is also two speed, self parking, if I can sort the wiring diagram......
JJMclure
Post by JJMclure »
cool, cheers guys, I really am just looking for some ideas. The mid plate and supporting framework isn't in yet but as you can see from the pic below there is nack all at the bottom of the screen
Most people in the kit car world use the old mini/ land rover motor and wheel boxes, looks very similar (probabbly the same) to the range rover one pictured.
Very adaptable, again with 2 speeds and park. Also reversable, LHD or RHD. and width of wheel boxes is easy to change with micro bore copper pipe and brake flaring tool
Correct
Main supplier for kit cars is S-V-C
Speak to them and they have all the bits to increase or dectease the sweep etc.
really helpful crowd - link above should help
JJMclure
Post by JJMclure »
nice one cheers guys!
Return to “Body & Strengthening”
