Hello folks, Im trying to get a measurement of a standard 2WD flywheel thickness, and also the distance from the back of the block (mating face with bellhousing) to the friction face of the flywheel.
Can anyone help?
Flywheel Thickness
- topcatcustom
Re: Flywheel Thickness
SD1 flywheel is 31mm thick.primer wrote:Hello folks, Im trying to get a measurement of a standard 2WD flywheel thickness, and also the distance from the back of the block (mating face with bellhousing) to the friction face of the flywheel.
Can anyone help?
Crankshaft flange is 7mm forward (ie towards front of engine)of bellhousing mount face so friction face to mating face is 31-7=24mm
Note, a steel flywheel from Real Steel is 3mm thinner than an SD1 flywheel.
Regards Denis
