dnb
Post by dnb »
You have just explained the problem. The firmware I use only has "Angular width of tooth" in it. Yours has both - typical version control issues... I am looking at 1.1.58 now, as this should suit us both well - it has the nitrous control you want as well as all the things I want.
You need to set angular width of tooth to 10.0 and angular width of missing tooth to 20.0
cheers mate,
will be handy using the same firmware.
just updating the msq on laptop now,
will have another go starting the car tomorrow, :wink:
still no cranking signal :cry:
Mark
Post by Mark »
Hi Tony,
Have you tried checking the crank position sensor ? When I fitted Emerald to my RS2000 I used a volt meter connected to the sensor and waved a spanner past the end and looked for a positive voltage on the approach to check the polarity. This would also check to see if the sensor was working.....probably !
Mark
bobtail84
Post by bobtail84 »
Tony, have you tried switching the wires around on the crank sensor? I know that MS won't see the signal if it's the wrong way round also is the sensor close enough. Just thinking out loud.
Jeff
Range Rover 3.9 with MegaSquirt and EDIS
www.essex-ms.co.uk
yup tried that mate :(
still nowt,
have tested the crank sensor and that seems to be working fine,
was told to test it at 200ma on a DVM and should see between 100-200ma
we got a reading of 02.4 when cranking
just realised had test meter on wrong setting lol.
will retest in morning.
got the sensor sorted had to space it off the trigger wheel a lot more,
now have a reading of 170.7 mv (needed between 100 and 200)
still no reading from the ecu though :shock:
looks like maybe an ecu fault, here we go again :lol:
So on with the car,
changed the old bilstien shocks to the new Gaz adjustables, (match the fronts)
The new mounting bracket for the line loc was finished so i fitted it,
Modded the dash panel to take the O/E Ford electric mirror switch.
The bonnet went back on;
All thats left now if im correct is just the rear brake lines to make,
then its ready for the road, (when it starts)
topcatcustom
Post by topcatcustom »
Leccy mirrors eh tony? Did you think about the extra weight?! :lol: Is the line lock electric too?
reason for the lecky mirrors the manual adjust ones have an adjustable joystick and it foul the roll cage,
Caprisport had a set of Ford electric mirrors that will fit the capri doors with a bit of work, so we decided to go that route,
the line lock is still the old manual lever type, will be electric though by the middle of next year, unless i find one cheap before hand.
r2d2hp
Post by r2d2hp »
Have you got a better picture of the trigger wheel setup? Normally the sensor has to sit within a few thou of the wheel.
Is your sensor being affected by the pulleys as trigger does not seem to stick out very far.
You could do with a scope really to monitor the signal
if we we close the gap the sensor generates over 200mv,
the test meter went off the scale,
if i had the money mate i would buy a scope,
i'll try and space it off the pulley a bit more and try again today.
r2d2hp
Post by r2d2hp »
Using a dvm is not good enough; you could have 200mv on noise. Had a look at page 31 and the trigger wheel looks to be same height as pulley so am wondering if sensor is picking up something from the pulley.
Think I would have placed trigger wheel the other side and made it stick out past the pulley so sensor can not be influenced by anything else
Maybe others more qualified can pass on there thoughts
edit
Sorry, Other side of pulley as there looks to be more space to get it it clean air. But am only guessing, may have nothing to do with it
other side of what mate?
