10% Off on SC Power engine mods for Rover V8's
PLEASE contact me before posting in here,
As i need to make sure what is being offered will benefit the members of the forum,
Have you used this supplier? And were they
Highly Rated
4
57%
Helpful
2
29%
Average
0
No votes
Poor
1
14%
Never Again
0
No votes
Total votes: 7
SC500
Post by SC500 »
We are now offering all members of the V8 owners forum 10% off on the following items:
Plenum Spacer:
Our Plenum spacer is designed to improve air efficiency by increasing the available air volume to the cylinders, improving throttle response and overall performance.This is achieved by fitting the spacer between the plenum and trumpet base, resulting with an increased volume of 0.55 litres. A 15% increase in volume that improves throttle response.
Dyno results with the spacer have demonstrated an increase in performance of 3hp/4ft.lbs torque.
Please check the website for more information.
V8 Owners price £112.50+vat
Bell Mouth Trumpets
These bell mouth trumpets were designed to improve the flow of air into the cylinders. The standard headers are not equal length so the trumpets were cut down to equalise this distance. That in conjunction the bell mouths increases power by 3bhp. Cut down lengths are supplied with the bell mouths
Heat Wrap for AFM
Any car will benefit from using this heat wrap for their Lucas AFM, the units are susceptible to heat so any protection you can give it is a good idea. The wrap is simple to install as it just fastens with Velcro strips sewn into the fabric.
V8 owners price £27+vat
Engine mount restraint bracket
Designed to support and strengthen the existing mounting, the restraint has been developed for and proven on our Supercharged range of cars.
These restraints produced from high quality steel and electroplated for corrosion protection are now available for all RV8 engine installations.
Please check the website for more information on this product.
http://www.sc-power.co.uk/SC%20Power%20 ... 20Mods.htm
Just mention your V8 owners username to obtain the 10% discount
All prices do not include delivery
David Harvey
Supercharged 5ltr TVR Chimaera now with Intercooler
www.sc-power.co.uk for vids and pics
SC500
Post by SC500 »
We now have in stock polyurethane engine mounts for the RV8. Please check the website for pictures.
We are doing a introductory price of £39 each inc vat, £5 for delivery.
Also we now have a new design plenum spacer, this is cheaper than the old one but still gives a good improvement in throttle response and an extra 5hp as proven on a rolling road.
This mod with our bell mouth trumpets and revised intake runner lengths will give your car an excellent improvement in response as well as another 5hp.
Please give us a call for more details on 01277 225000 or go to the website www.sc-power.co.uk.
David
SC500
Post by SC500 »
Update on the poly mounts
We now offer three grades of hardness, the reds which are for road, black which is road/race and orange for race/sprint cars.
SC500
Post by SC500 »
Polyurethane engine mounts for RV8 offering extended life and durability over the standard rubber mounts.
Three choices of hardness to perfectly suit your requirements.
SC500
Post by SC500 »
An excellent cheap improvement that you can do to your RV8 engine is insulate the inlet manifold from the trumpet base. This helps reduce the heat transfer into the trumpet base and plenum top and from this helps to reduce intake temperatures.
SC500
Post by SC500 »
SC Power nows offers Millers Oil for N/A, forced induction and running in oil for the RV8.
Also Castrol SRF Synthetic Racing Brake Fluid
http://sc-power.co.uk/SC%20Power-millers-oil.html
Return to “Discounts Offered To Forum Members”
