Rev counter erratic -ness !
Hi Guys since the misfire on the engine last month i've now noticed the rev counter is quite erratic, flipping up and down and never quite stable, ignition is pertronix coil and ignitor, rev conter is similar to the "tim" type gauge, 2" in a pod, anyone come across this before or is something about to go west
So thats where it went !
First place to check is the low tension supply to the coil as the tacho is indicating a problem in this area, could be as simple as a bad connection from ignition to coill.
If it's not that then possibly one of the ignition components is breaking down under load, so a check of the coil and amp if one is fitted.
oops
Just realised i put this in the wrong section
the charging is fine, i have a volt moeter fitted, i need to have a good look through the ignition system again to see if i've missed something
