V8 Healeys have a poxy small engine bay and no space for a big radiator and we all have cooling problems but there are guys in Texas who have less hassle than I do.
If I run the fan all the time and can keep the car moving then we're OK but traffic lights and stop-go traffic sees the temp start to climb. I'm running a 12" pusher fan and might be able to squeeze in two 10" slimline pullers. That might give me just enough cooling as the rad can't be increased in size but it's supposed to be good for 400bhp.
My biggest problem is dumping water. I've got a header tank fed off the water neck extension with a return to the bottom hose which seems to work until the temperature reaches 90 and then the coolant starts being fed out of the header tank.
Anybody want to comment on the setup. Is the header tank setup
wrong???? H E L P
