Gear and final drve Ratios
Any body have a ratio chart so can work out best overall gearing for 1/4 mile times for my TR7 ?
Tricky
See a few spaces up on the Drivetrain & Transmission Area page, Final drive ratio calculator gives you all the options.
or direct link
http://www.v8forum.co.uk/forum/viewtopic.php?t=5328
or direct link
- davemgb
- Helpful or Confused
There are some good bits of software out there on the net to do performance calcs for 1/4 mile racing. You will need accurate power and torque curves for you engine plus full details of your transmission. Then you will be able to check the software results against real life to get the values for gear change duration and tyre slip right. Don't forget you will need a way of relating any results to a set of standard conditions to make a meaningful comparison.
And if you think this reply is not helpful then you need to think some more.
Hi Tricky,
The works rally cars ran Salisbury HA ( Mopar Dana )rear ends because the standard axle caused problems. I think
that these axles as well as being fitted to early Jags were also found on Scimitars
There are several people on here that know more than i do about Scimitars so hopefully they will tell you if this is the case, will need brackets welding on ect.
http://cgi.ebay.co.uk/Reliant-Scimitar- ... 7C294%3A50
In the states they shorten Ford rear ends to fit when taking a TR7 V8 drag racing, more than strong enough
and readly available
Cheers John
Cheers John
LIVE LIFE A QUARTER OF A MILE AT A TIME.
