Hi guys, I just put an sd1 v8 in my mgb running an lt77 gearbox.
Does anyone know where I can get the clutch hose to connect the slave and up to the master cylinder, as cant find it anywhere, cheers
lt77 slave cylinder hose??
Order up the required parts from the Aeroquip or Goodrich components lists at Rally design and make them yourself.
A tip if you do this - sleeve the braid (before assembly) with 6" of clear PVC tubing where it passes near the starter motor if you have a starter motor with the bottom solenoid.
Andrew
Andrew
4.5L V8 Ginetta G27
