speedo drive on lt77
a1100ndy
Post by a1100ndy »
have lt77 box in my sierra with cosworth back axle the gearbox has an electronic pick up for the speedo but need to change to mechanical drive to run cable to standard speedo does anyone have any idea which drive i need and where can they be got :?: many thanks
harvey
Post by harvey »
The standard early cable driven gear and its sleeve from an early SD1 is a direct replacement for the later electronic sender. In fact any cable LT77 box should get you a gear, after that it's just a matter of recalibrating the head to make it accurate.
a1100ndy
Post by a1100ndy »
thanks m8 thats good to know ive been told that there are different sized drives have not been able to find anyone who sells them
harvey
Post by harvey »
The driven gears will have different numbers of teeth depending on the original application, but as the LT77 was never fitted in a Sierra you can fit any one as you'll need to recalibrate the head anyway.
Try Rimmer Bros for new driven gears, and they probably do the sleeve it sits in as well.
Pocket rocket
Post by Pocket rocket »
Rimmer Bros did do them - but they ain't cheap
http://www.rimmerbros.co.uk/rimmer/rove ... Transducer
:( SORRY - just noticed they don't appear to be in stock. Might be worth phoning them anyway..
a1100ndy
Post by a1100ndy »
will do never thought about them is it tricky to recalibrate the speedo or is that a specialist job
harvey
Post by harvey »
a1100ndy wrote:will do never thought about them is it tricky to recalibrate the speedo or is that a specialist job
Google "Speedy Cables" and they can do it, and their site shows you how to do the calculations for them to be able to do it for you.
They can also custom make a cable to fit both ends as well.
harvey
Post by harvey »
Someone on here must have the speedo gear and sleeve secondhand that they would be able to sell you.
a1100ndy
Post by a1100ndy »
thanks for all the help, gives me a point in the write direction, been working off and on the car for a while and need to get the finger out and get it running this summer, :lol: or so i keep telling myself
ged
Post by ged »
Hi a1100ndy,
There are 2 mechanical speedo drives that I am aware of, you'll have to pick the one nearest to your final drive ratio.
3500-20 teeth orange for 3.08-1 axle ratio or
2600/2300 23 teeth black 3.45-1 ratio.
Hope this helps
Ged
Post by CastleMGBV8 »
Yes final drive ratio, and tyre size come into the equation.
http://www.v8forum.co.uk/forum/viewtopic.php?t=5079
Might do the job.
Some speedometers can be recalibrated, some cant. When I put the 150MPH speedo in my Sherpa, I investigated this point, and found that it's too new (only 20 years old!) to be recalibrated.
Instead you have to buy a correction gearbox which sits in the middle of the speedo cable (which in effect becomes two cables) to make the adjustment.
I did the various calcs, and specificed that a certain RPM on the speedo drive from the gearbox was 60MPH road speed.
I now have a speedo that is c*ck on. However, because the manufacturers make the speed part optimistic and the odometer accurate, I now have an accurate speedo but lousy odometer!!!
katanaman
Post by katanaman »
There are loads of options on the ratios. Last set I bought was from an LDV van dealer so try one of them.
a1100ndy
Post by a1100ndy »
got a speedo drive thanks Keith, and thanks to all for your help
