Anyone got a link etc the gearbox numbers for the R380?
the box i have looked at has 28A*******J
are the numbers the same as LT77? as they start G**A
R380 5 speed gearbox numbers needed.
- ged
I got this off the cobra forum.
Hope it helps.
Ged.
RE: Rover LT77 Gearbox
Stan the SD1 box is fairy substancial, but if you use hydraulic fluid/power steering to keep it lubricated then it will blow, with any more than normal road work, trust me I have got rid of two. Use fully synthetic, or EP 80 gear oil which was previously stated in hand book prior to 1978. I have now got the replacement R380 sports box 28A which is a direct replacement for the old LT77 (SD1) unit which runs on fully synthetic; no more problems. Used in the TVR, Morgan, & MGRV8. The box fits but new mountings required as they are 2" further back, but prop and clutch okay. hope this is of some help!! Eric.
Hope it helps.
Ged.
Cheers ged
looks like a tvr/morgan box then
sweeeeeeeeeeeeeeeet,
any one got the gear ratios plz
that for the 28A R380
JP?
JP?
