Can any one recomend a good off the shelf system to do away with the afm. Vems, gems , mega squirt etc. i dont want to be messing about soldering i want to buy a system all ready to bolt on to a twin plenum 4ltr tvr engine. Appreciate then it will need to be set up on a rolling road.
shaun.
doing away with air flow meter
if all you want to do is control fuel then MS will be the one to go for as its by far the cheapest in that trim. If you want to go full ignition then VEMS is your next one up cost wise, haven't looked lately but it was marginally cheaper than MS with all the ignition stuff grafted in. Emerald is probably your next cost wise. Obviously everyone has their own fav and many will say go for MS but if your having to get it built you might as well look at the others.
TBH I dont think you will get a total PLUG N PLAY system, there will be a certain amount of wiring needed, Emerald do a semi built loom, and I would guess if you speak to Karl he may do the complete thing I you are willing to leave the car with him, The added bomus would be, Dave could put it up on the rollers and get it all done at once.
Lots of choices of ECUs out there,
http://www.jenvey.co.uk/
Have a look in management,
THE SMOKING GNU
