Not going to do that many miles unless I really like it or one of the sportscars needs major work.
I know nothing of LPG other than the basic sort with a single vaporiser in the inlet. What's the deal if I want LPG on the later Bosch/Sagem variant of the Rv8? I assume an additional fuel ECU and a second row of fuel rails and injectors as a minimum.
My preference would be the 2nd set of injectors all controlled with the original management, and switch fuel and timing maps for LPG so that I can extract decent performance from the LPG mode. I may even be convinced to increase the compression when I change the camshaft since LPG has a RON of 114
I know VEMS can do 2 maps now, but I don't want yet another "project" vehicle - I want to retain as much OEM stuff as possible, I wouldn't object to making a switchable dual EEPROM board to go in the OEM ECU and have a relay to activate the appropriate injectors...
So is such a system available off-the-shelf? And is DIY fitting + inspection for insurance an option? (I am reasonably competent)
Thanks.
