Group A push rods
deetes
Group A push rods
Post by deetes »
Can anyone point me in the right direction for pushrods to use with Group A adjustable rockers and hydraulic lifters?
Not decided on the spec of the cam yet, but possibly V8 Development's Stealth cam.
chodjinn
Post by chodjinn »
Like I said before, John Eales will do you custom ones for £260, or DJE will do you titanium ones for £300. Rockers in the post tomorrow mate ;p)
Post by CastleMGBV8 »
Real Steel can do you a chrome moly push rod kit with a variety of ends to suit various set ups depending on what cup size you need and the type of lifters you are going to be using.
Warning ball ends vary depending on which lifters you use, the Crane hi rev lifters I used require a ball end of 5/32" as opposed to the standard Rover size of 3/16"
Cost is around £120.00 for the kit and you can have the length optimised for your engine as they will probably need to be shorter than standard which is 8.050"
Cost me £30 to have the rods shortened and the ends press fitted at an engineering shop.
chodjinn
Post by chodjinn »
remember the group A rockers use a cup and ball, not ball and ball so no off-the-shelf kit will work, inc. the reel steel stuff (i checked!), unless you buy from the US that is then the choice is endless! Shame about the exchange rate at the moment :roll:
Thought they could do the cup ends, if not you could order them from seperately from one of the suppliers in th US would only be a very small
package and wouldn't cost much to have them posted.
chodjinn
Post by chodjinn »
Well I dunno then kevin, when i rang them they were about as helpful as RPi, and never mentioned cupped ends for their pushrods . . . almost like they didn't need the money!
Sometimes it depends on who you speak to, the best guy at RS on pushrods is John and he knows all the Chevy stuff as well.
They may not stock cup ends but as they have regular shipments from the states they could probably get a set if the size is known and you ask nicely. Otherwise order direct as I suggested. Alternatively once the required length is known poosibly those ford pushrods that I think Boosted mentioned.
Crane will do a custom set at your required length and with one cup and one ball end to match the ball size of the rocker and the cup size in the lifter you intend to use.
http://www.cranecams.com/pdf/Page553.pdf
Hope thats a help.
deetes
Post by deetes »
Cheers everyone.
Spoke to John Eales and he reckoned he could supply what ever length I needed for £15 a pop.
Still have to decide what cam and lifters to use.
