Twin plenum? Worth it or not......
Lewis
Post by Lewis »
Hello all,
After browsing thev8kid's excellent Capri site I've become increasingly drawn to the prospect of fitting a twin plenum to my 3.5EFi....it'd just look great under the bonnet!
Are there actually any gains to be had with a TP or is it down to a combination of things rather than just the extra hole for a bit more air to flow through?
Is there anything else that goes with the TP hood or could I just fit the plenum and appropriate hoses?
I understand they're a bit rare thesedays - what could I expect to pay for one?
8-)
:cry:
Full of questions aren't I :lol:
Looks jolly tight in there actually.... :? I might be converting to MS soon so could ditch the flapper...that'd free it up a bit :)
Thanks all,
Lewis
katanaman
Post by katanaman »
depends what power you want if its 300+ bhp then its worth it if less then no its just eye candy IMHO. The kit is now old and worn and parts are hard to come by for them as Tony will testify.
yup if it breaks, you get it made now for a price and not buy off the shelf :(
kokkolanpoika
Post by kokkolanpoika »
1x std 65mm Throtle flows about 280-300hp on V8
1x 71mm Throtle flows about +400Hp
2X 65mm(twin plenum) flows i think +550hp.
You need bigger throtle if you want to make over 300hp.
But 2x65mm is quite big for 300hp. But i think it work. Throtle responce is quicker in twin plenum, but low rpm behaviour is quite agressive, because 2x65mm throtles give you 2 time more air than 1x65mm @ low rpm.
(Excample: i dont know how mutch 300hp engine need air, but i estimate some numbers? your engine need i think about 140cfm air if it makes about say 300hp?
And those twin plenum flows i think over 250-300cfm?)
You need good heads if you want to make lot of power, this throtle is not the limiting part.
:shock:
This 71mm throtle is good for any tuned rover v8.
One question. Why use twin plenum if use std Y- pipe/adaptor?
Not sure, but i think this Y-pipe bore is near of std 65mm?
Timo
chodjinn
Post by chodjinn »
I saw a few of these on the eBay over xmas, they go for quite a bit of cash though (£300+)
You could always get two standard plenums and do a cut+shut job, bit cheaper, unusual, more spares, but more work!
Lewis
Post by Lewis »
Like Mr Ringwood's?
I have the facilities to do that.... :twisted:
chodjinn
Post by chodjinn »
aye that's the stuff mate! I'd love to do it with my motor, but impractical what with the twin turbos and intercooler :roll:
Lewis
Post by Lewis »
:lol: :twisted:
daxtojeiro
Forum Sponsor
Forum Sponsor
Post by daxtojeiro »
If you want a twin intake then do the siamese setup, obviously you cant run the Lucas with it but then I guess youve already dumped that, as the AFM will remove any gains a twin plenum setup wll bring anyhow. The reason I recommend the siamese is price, it cost me £25 for the welding, the plenums were freely sent to me, but even if you bought them they are very very cheap on EBay. All you have to do is get them cut and welded where as a twin plenum setup seems to go for silly money,
Phil
JSF55
Post by JSF55 »
I take it with this set uo you would need a linkage between both intakes to control the throttle ? how critical would the linkage have to be? would 2 cables to the accelerator pedal work? any pictures? john
So thats where it went !
hey phil how did you cut the plenums? -
daxtojeiro
Forum Sponsor
Forum Sponsor
Hi there,
I cut them in a bandsaw at work, simply bolted it down and cut them. I didnt cut them down the middle, as I wanted to keep the flat part that the Idle valve sits on at the rear, rather than half at the front and half at the back.
I bolted the 2 bits to an old trumpet base and got it welded up. Then a lot of fileing, polishing, etc!!
The throttle linkage between the 2 makes absolutely no difference as the plenum is shared between the 2, I have mine so the original side opens up for about 20% of the way before the next one starts to open. This is done with 2 throttle cables, both attached to the throttle pedal. Simply make one a little slacker than the other, that way you dont loose any drivability at low throttle openings. Ive driven an ACT triple plenum and that was a complete nightmare in town had to slip the clutch all the time, where as this setup is superb! Throttle responce is very much improved too :)
Phil
Lewis
Post by Lewis »
Awesome stuff! Definitely something I might consider.
Thankyou for the information and pictures! 8-)
Wotland
Post by Wotland »
Hi There,
May be something more suitable for your application. Triumph Rover Spares (Londsale - Australia) offers an twin 57mm throttle bodies converstion for $775AUD. This kit is based on Jenvey throttle body.
Cheer.
ihatesissycars
Post by ihatesissycars »
That is pretty much identical to my ACT twin plenum which uses the same bodies but on a carbon plenum top.
