clutch
poo slinger
clutch
Post by poo slinger »
do rover v8's run off cable or hydrolic clutch?
ramon alban
Post by ramon alban »
Hello Poo,
Hydraulics with a clutch master and slave cylinders
poo slinger
damn, would that mean i have to change my pedal box or can i convert to cable?
topcatcustom
Post by topcatcustom »
With some ingenuity you could probably convert to cable but why would you want to?
Several of the Ford owners have converted from a cable to Hydraulic using an adaptor box and a short cable from the existing pedel box, there are even some photos on here somwhere (I suspect in this section). Ask Ian Stewart or Tony.
JP.
Post by JP. »
I have welded a bracked on the steering colum that holds the master just above the pedal in the Capri.
The fluid canister sits in the enginebay.
Normaly it puls the cable, now it pushes the master ( cause its above the pedal now)
poo slinger
i mite just convert it then :P
