After installing my 3.9 back into my sd1 (had some clutch issues) I went to turn it over tonight and there is no spark at the plugs.
I took off the middle HT lead from the dizzy cap and tested that. Again no spark.
I got my volt tester and made sure there was power going to the coil.. all ok there.
ummm help? I am not sure why no spark is happening. Ive not played round with the distributor or anything and literally took the motor out and put it back in. All the wires are connected. I swapped out the coil in case it was faulty but sitll no joy..
Your help would be greatly appreciated as I have done all the tests advised in the manual
Andy
