Which water temperature sender unit?
spartanv8
Post by spartanv8 »
Which water temperature sender unit should I use for a Classic Smiths water temperatue gauge? I know I will need an adapter but what size?
I run a 3.5 from a P6 in a Spartan.
Fil
Post by ian.stewart »
use the one Smiths supply with the instrument, then you will know its giving you the right readings
THE SMOKING GNU
spartanv8
Post by spartanv8 »
I bought a couple of Smiths water temp gauges from Ebay to replace the Tim one as all my other gauges are Smiths, so no sender with them.
If it's got booby bits or tires it's going to be trouble!
Speak to speedy Cables - they are the manufacturers
http://www.speedycables.co.uk/
JSF55
Post by JSF55 »
Intermotor part number 52730 fits and works well with the smiths "mini " gauge i have, obviously through a 9v supply !
So thats where it went !
spartanv8
Post by spartanv8 »
Thanks for the replies.
I have 10 volts through a voltage reducer for the gauges but not 9 volts! How do you get 9 volts?
JSF55
Post by JSF55 »
Oops sorry it's 10v your right ! i bought one of these, and just checked the info !
http://cgi.ebay.co.uk/Semiconductor-Vol ... dZViewItem
spartanv8
Post by spartanv8 »
Yes it's similar to the one I've got.
I bought a Smiths sender from Europa Spares but the Smiths gauge only shows just over cold when up to normal temperature. Where as the Tims gauge, I want to replace with a Smiths one, shows normal temperature. Weird or what?
spartanv8
Post by spartanv8 »
It was a faulty gauge, changed it for another one and it works fine now. Thanks for all your help.
Fil
Return to “Cooling Area”
