Front cover
Front cover
Does anyone know where I can get a New front cover for my engine, I dont think I can fit a Jems as the sump area is different or so I have been told, Intermediate cover?? I think my pump is a wee bit shagged, I may just try some new gears unless I can find a new cover as well. I not to botherd what cover I run as I am running coil packs.
THE SMOKING GNU
i know where there is a gems cover and metal; sump mate,
new pick up alos,
you will need to change your cam though if you use the gems cover,
CSR on here has the one back i was going to use, as now got an interim cover for mine,
new pick up alos,
good luck mate,
took me a while to get one,
keep eye on ebay, the covers alone go for around £100 upwards with out pulleys.
i was lucky with mine
Cant see the Covers on his site, but knowing me, Im probably looking in the wrong place,
Anyway, Ive been up to Dingocroft today and got some new pump gears, lets see what happens after I have fitted them,
THE SMOKING GNU
Hi Ian,
Fitted one of the covers Kevin mentioned on my 4.6 took a little work changing the drive gear over, making up a timing pionter and alternator bottom mount but nothing exaclty hard and the pump chamber is deeper than a SD1. The SD1 base fits straight on as does the gaskets. The oil seal outer diameter is different but inner is the same and you need to blank fuel pump hole.
http://www.v8tuner.co.uk/product.php?id=421
Cheers John
Cheers John
LIVE LIFE A QUARTER OF A MILE AT A TIME.
That would be lovely, noticed its not got the redundant fuel pump flange whichI modify to take my crank sensor,
In the meantime, I have been formulating a cunning plan,, not too hard either, I can see me on the mill at the weekend, make new oversize gears, perhaps 1 mm larger, and machine the pockets out in the pump to suit the oversize rotors, I dont see why it wont work, just a case of me getting my ar-e in gear,
THE SMOKING GNU
seight
I think that's a Buick V6 cover.john 215 wrote:Hi Ian,
Cheers John
A bit like this one,
http://cgi.ebay.com/ebaymotors/_Car-Tru ... .m20.l1116
THE SMOKING GNU
