hi there, am newby, but have been reading with interest for a year now .
i have fitted a zfhp22 from a xj40,to a rv8. trouble is, got no drive at all
have read previous posts , but need help please. hope to hear from someone soon ta
zfhp22 fitting probs
Worked fine on mine, as long as you have the correct convertor, thats the one from a zfhp22 boxed range rover it should be right, did you use all the spacers in the correct order?
Some pics here
http://community.webshots.com/album/555 ... t?start=60
Some pics here
So thats where it went !
oh wow! guy i bought the convertor off said they were universal.
story so far is, got 3.5efi, bought and gutted xj40 for parts , had to get convertor,so bought one. fitted it all together after reading forum for tips,
zf box tilted to one side but is ok, fitted into chassis ,started it and ran ok, but no drive.
looks like i will have to get another box with matching convertor! i might not have the right convertor
thanks . will have to source one locally.
hi chris, no drive at all. so took engine & box out , on removal of torque converter saw the broken teeth of the oil pump! i managed to get a s/hand pump from a local r rover breaker for 20 quid, rebuilt box..... hey presto oil pressure! i am putting an extra 2.5mm shim in behind the flexiplate to take up a 5mm discrepancy, so i have 49mm from bellhousing to t/ converter, and 51mm from engine to flexiplate.
most of my info comes from reading all your posts, great forum guys.
fitting box to engine tommorow, and hopefully refitting over next few days.
many thanks guys.
ps hope to add a few pics of my first ever project soon.
many thanks guys.
