i want to put a side exit with a single small box in the exsisting place and have the pipe exit just before the drivers rear wheel...can anyone give me any pointers in text..links..or pics to help me along
cheers...brian
side exit zorst
roofman
- Helpful or Confused
side exit zorst
91 classic vouge...2" lift...31-12.50/15 muds and running a 3.5
You are going to struggle routing over the chassis rails. You wouldn't want to go below either. Only option i think is to cut a hole through the chassis and sleeve it with some heavy guage pipe - which isn't great either.
why not exit on the passenger side, as from memory thats the side the exhaust runs along?
roofman
yea ime going to do the crossover at downpipe area...dont want to waste the v8 burble on the passangersEliot wrote:You are going to struggle routing over the chassis rails. You wouldn't want to go below either. Only option i think is to cut a hole through the chassis and sleeve it with some heavy guage pipe - which isn't great either.
