Fuel pump
Fuel pump
Can anyone tell me if its possible to use a fuel injection petrol pump for a carb engine (3.5 running quad sidedraughts) as long as you have a regulator fitted to restrict the pressure, would a filter king regulator work? or should I sell this pump (brand new in the box) and buy a facet or something similar.
MARSHO
I would think it would be possible bt you would also need a return to the tank as the HP pump run on spinning vanes and warm the fuel in the process so if there was not a full flow the fuel getting to the carbs would be hot.
I would thus suggest something designed for Low pressure
cheers
cheers
It will work perfectly fine with a suitable return style regulator.
Used them plenty of times, as do Metro Turbos, Lotus Esprit turbos, R5 Turbo etc etc etc
FPR009
http://www.fuelsystem.co.uk/regulators.htm
The fact it isnt turbocharged, is irrelevant. You could apply vacuum to the top port if you want, or just leave it open for a fixed fuel pressure. With vac applied, fuel pressure will be lowered when there is vacuum present ( ie idle and part throttle )
There may be other return style regs available from FSE, or Holley, Aeromotive or any of the common US sources will do regs too.
FPR009
True, I but I did mention it must use a return, and I assume the reason he is asking, is that his car is already equipped with en efi setup ???chodjinn wrote:Depends if his tank is suited for a return line or not. If its not, it may be more hassle to sort that out than buy a low pressure pump & regulator.
If it isnt, it would definately be easier to buy a carb specific pump.
Fuel pump
Sorry about the delay but sometimes work does get in the way, the tank is a small spun alloy type as used on hot rods etc so there is no return, will get afacet or similar, thanks for all the replys cheers David.
MARSHO
