I am with Stevie here the way your describing it will not increase boost, all you could possibly be doing is causing a lag at the wastegate and that's extremely doubtful.. Its simple physics, there is no flow so you cant restrict anything just as Stevie said.. The only way what your describing could possibly work is if you made a T on the boost pipe and used the restrictor on the vent part I.E a fixed bleed valve.CastleMGBV8 wrote:Stevie,
All you are doing by inserting a short piece of brake pipe into the boost hose is reducing the internal bore and therefore the wastegate will read a lower pressure. It may sound crude but it is very effective, and I know several people who have done it and it costs nothing.
Increasing the boost?
Again, in a dead ended system such as this, inserting a restriction will make no difference whatsoever.CastleMGBV8 wrote:Stevie,
The only thing that can make a difference, is an air leak.
It doesnt matter if you blow thru a garden hose, or a straw into a dead end. Its still a sealed system, so pressure remains the same. One will just fill faster than the other. So at best, you may introduce a boost spike if the restriction was very big, but that is an even worse approach that a dinosaur bleed valve ( which in all fairness, can work very well in some setups )
Until you start bleeding off air, you have no chance of proper boost control or raising.
roofman
- Helpful or Confused
i own and run a nissan 300zx twin turbo..the standed boost is 9 psi...ime now running 16-17 psi by inserting 2 mig welding tips (1mm inside diameter) inside the wastegate actuator lines which slows down the boost signal to the actuatorsCastleMGBV8 wrote:Stevie,
91 classic vouge...2" lift...31-12.50/15 muds and running a 3.5
