Brief ticking
pwd95
Brief ticking
Post by pwd95 »
I've got this slight 'tick when the engine returns to idle. When its warm if you let it idle, then raise the revs a bit it's fine but as it returns to idle it 'ticks' for a second or two. This is the only circumstance that it ticks :?
When I changed the oil to Valvoline 20/50 it got worst so I've put Magnatec 10/40 in now & it's much better. Could it be the pick up in the sump?
ETA it's a 5 litre TVR/Rover V8.
Ta in advance :)
katanaman
Post by katanaman »
I cant remember but doesn't the tvr have the crank driven pump? if so you should be using 10-40 anyway. what's the mileage?
pwd95
Post by pwd95 »
It's got the later serpentine front end & the milage is just under 40k.
It might be worth measuring the oil pressure to see what it's doing....
v8alex
Post by v8alex »
Do you know if the tick is mechanical or electrical ?
I had a ticking from mine at idle - eventually put down to a blowing exhaust gasket and it was the noise of the tappets / valvetrain coming out. Bit of exhaust assembly paste sorted it. However mine was a continual ticking, not short lived, so I guess the issue is different.
Alex
pwd95
Post by pwd95 »
Thanks for the reply's chaps. The oil pressure is very good. It's only when it returns to idle. If you raise the revs just slightly it goes away, then comes back as it returns to idle for a couple of secs. :?
It's as if one of the followers is loosing & taking a few seconds to fill again.
it sounds as you say, one or more of your lifters is bleading down, I would double check your exharst for leaks though.
pwd95
Post by pwd95 »
Bin a while so a quick update. Changed the oil for a 5-40 synth with an engine flush before, (2k rpm for 20 mins) & the tick has gone away when warm. Still there a bit when warming up, not on first start when cold.
