backfire
Blown v8
backfire
Post by Blown v8 »
5.0l 4-71 supercharged- just replaced the blower to manifold gasket, warmed it up gentlly till the oil cooler was functioning. Gave it some throttle, as it came off the throttle ,a massive backfire, blowing said gasket again, and not firing on number 7 ! checked static cylinder pressures and A OK any 1 got any ideas before i rip the engine out for the upteenth time in 22 years ! 1 one day i will get it right
RoverP6B
Post by RoverP6B »
Backfires can usually be attributed to lean running.
How do your plugs look?
Ron.
4.6 Rover 3500 P6B
Possibly incorrect timing causing it to fire when Inlet valve is open.
Is it Carb feeding the supercharger? If so it could be sucking in a load of fuel in above the throttle and then it managing to dump it in the plenum and getting raw fuel through and detonating.
Blown v8
Post by Blown v8 »
plugs look good. holley 650 double pumper above blower. Had engine dynoed a couple of years ago when engine was built.Cars been laid up for 4 months . drained tank and replenished with fresh petrol, maybe a look into the carb to see whats going on is needed !
Pretty good chance that you are getting fuel puddling in the inlet when you lift off, a small air leak after the carb would give you a nice big load of charge in the inlet ready to go pop, and as you have the thing on over run then the timing is heavily advanced and it fires with the inlet valve still just open bang! :shock:
May be wrong but I would get the WD 40 out and start hunting air leaks post carb above the SC (or in the body of the SC).
