New Capri Brakes.
the handbrake is cable operated as normal but on the calipers instead of shoes and drums.
no probs mate
You have a reply to your PM but for any on else that has an interest -Sorry to be cheeky
What do these discs normally fit ? I'm running Focus ST170 discs on my XR4x4 daily driver and they are only 300 mm IIRC
Look at the kit on ebay right now - search on "Cosworth brake kit"
Uses Focus ST 324 discs and brembo calipers - serious stuff like tony's but to suit the Sierra strut.
Just some of what we do
Hi mate,
welcome to the forum.
i recognise you from the capri power forum yeah?
anyway, i use a 2.0 servo and no bias valve fitted,
Hi mate yeah I think I sort of met you last year at the classic ford day at pod but you were quite busy having just made your quickest pass to date !
I have the 2 l servo as well as the mondeo calipers and cossie discs on the front and the granada rear calipers on discs on the rear. I just plumbed them straight in to the the brakelines that were originally in the car therefore using the original distribution block.
They ae a hell of a lot better than the originals but seem to lack that 'new car' bite !
I was thinking of chnging the servo but if that is what you are using then I guess it should be ok and I will have to start looking elsewhere !
whats pads etc you using?
Whatever we do, we never seem to get that "new car bite"
Not sure exactly why but things like the pedal box gometry and bulkhead flex
must have a lot to do with it.
The set-up on Tony's car is just awesome. It pulls the car down from 140 to
the right side of legal with total confidence - not a hint of pull or fade.
I knew it would be good, but that good? No, that's way beyond what we expected.
Wish the Z28 stopped half as good!!
