Alternative to stretch bolts on later conrods ?
Wotland
Post by Wotland »
Hello,
Do you know if it is possible to use high grade standard bolts instead of stretch bolts on later 4.0/4.6 rods ?
Thank
katanaman
Post by katanaman »
Do you mean as in standard hex head bolt or standard rod bolts? If hex bolts then no there isn't any room for the hex on either the head or the nut. It also needs to be a fine thread for accurate torquing and clamping forces. I would imagine the shoulder could be quite critical as well to keep everything lined up properly. I didn't actually know they used stretch bolts to be honest. Don't like the sounds of that but then I don't like stretch bolts generally anyway. My top tip here would be to use ARP rod bolts.
TVRleigh
Re: Alternative to stretch bolts on later conrods ?
Post by TVRleigh »
Wotland wrote:Hello,
Thank
Are the bolts on the rods strech ones then.
Current V8 car TVR 400SE 240 BHP
Current Project TVR Tasmin Race, with 3.9 running at 230 BHP
Currently building a 4.6 300 BHP Xbolted Engine for it. Solid Lifters and Group A rockers, Stange 4 heads, Pocketed piston, fully balanced.
Wotland
Post by Wotland »
Myself I don't like stretch bolt. First you can use it only one time and secondly after angular torquing you can't check nothing.
RoverP6B
Post by RoverP6B »
It is my understanding that only head bolts are "stretch bolts". Connecting rod bolts like main bearing cap bolts are all high tensile.
On a 4.6, the standard Rover high tensile bolts for rod and main caps are totally suitable for all applications including racing.
Ron.
4.6 Rover 3500 P6B
RoverP6B
Post by RoverP6B »
Confirmation from the Land Rover engine manuals covering all 3.5, 3.9. 4.0, 4.2 and 4.6 litre engines, that stretch bolts are not used for connecting rods.
Connecting rod bolts are high tensile only and unlike stretch bolts are totally reusable.
Ron.
4.6 Rover 3500 P6B
Wotland
Post by Wotland »
Thank you Ron :D .
I posted this topic because rod bolts on 4.0/4.6 are torque and angle setting type ( 20 NM and then 90o more) like head bolts on 4.0/4.6.
So I suspected rod bolts waren also ''stretch bolts''.
