14CU or 14CUX ECU Circuit Diag
ramon alban
- Knows His Stuff
Does anybody have a link or a PDF for the Lucas/Rover V8 14CU or 14CUX ECU Circuit Diagrams please.
Some information you may find useful here:
http://www.users.zetnet.co.uk/barnes_fi ... /index.htm
ramon alban
- Knows His Stuff
No just the almighty Prince of Darknessramon alban wrote: Is it a conspiracy from the depths of the CIA to keep the ccts secret?
ramon alban
- Knows His Stuff
Hello Chris,
I've got the "less intellectual"
4CU Flapper schematics for U.S. TR8/SD1/RR on my website.
They give a great insight what is going on inside, particularly with the full load acceleration enrichment circuits and other sensor input circuits.
This leads to the possibility for us amateurs figuring out how they work without being held to ransom.
So I'm hoping that similar stuff has emerged for the 14CUX later unit.
Ramon
Ramon
Well I admit to being staggered by that. I guess it's a reverse engineered circuit though rather than the genuine article from Lucas. But no matter, the important stuff is there!ramon alban wrote:Hello Chris,
I've got the "less intellectual"4CU Flapper schematics for U.S. TR8/SD1/RR on my website.
Ramon
Slightly OT - the Pin1 input (Tach signal) input circuit shows that there's no need for that external resistor (at least, not from a functional point of view)
ramon alban
- Knows His Stuff
Hello Chris,
Still looking for 14CUX circuits.
Ramon
ChrisJC wrote: Well I admit to being staggered by that. I guess it's a reverse engineered circuit though rather than the genuine article from Lucas. But no matter, the important stuff is there!
I dont think reverse engineering would have generated those PCB layout but its clearly not a Lucas source.
Probably a US based franchised repair outfit who had to have the circuits and they just got pirated out of the side door.
Functionally perhaps, but I think on balance the 6.8 k ohm resistor + the 10 k ohm resistor forming a total of say 17 k ohm in conjuction with the 560 pico farad capacitor would have an effect on cleaning up the signal.
Take away the 6.8 k and the result may be different.
Then there is the issue of an accidental short circuit on the pin 1 side of the resistor?
All speculation of course.
Ramon
ramon alban
- Knows His Stuff
