where is it?
just before i tock my engine out i couldnt get it to start, so i gave up and removed it, between it runnign and it not i had most stuff off and the ecu out, i remember thinkign i didnt know where this was?
Ralph
enertia switch
On my k reg Vogue se the fuel pump stopped working, it wasn't the inertia switch, the wire to the pump ran between the underside of the boot floor and above the fuel tank, eventually it wore through the insulation and underseal and shorted out to the underside of the boot floor. Burnt out the rear loom with it. worth a check this hasn't happened here.
the white/black wire wasnt doing anything so it was the ecu not turning it on, so obviously there was no power going to the purple/white wire.
i recon this sugests either the ecu is broken, or its not running the engine for some reason like the inertia switch has been triped.
this was a vogue SE to.
Ralph
Ralph
