I was about to purchase some of the bullet valve guides which i read were better but my machine shop says that they don't even bother with changing the valve guides............possibility of galling the valve guide bore........they would re and re the existing valve guide before doing the 3 angle valve job...........is this going to flow as good as new valve guides........they say yes but i'm not sure
Bullet valve guides
re-lining the guides is a popular alternative - but for the performance benefit smaller bullet/tapered guides are the way to go - The preferred method of removal of the RV8 guides is to machine them out rather than pushing them. Other way is in the oven and heat the heads then press the guides out.
Andrew
Andrew
Bullet guides will flow better whatever is done and is usually one of the first things you would do to a set of heads. No point doing big valve multi angle anything when there is a dirty great big guide in the way. There shouldn't be any problem fitting new guides, many people do it at home never mind a machine shop.
as said above, heat the heads in the oven and push them out with a stepped drift that goes down the center of the guide and has a shoulder that is the same size or a very small amount less in diamiter than the outside diamiter of the guide, don't be tempted to bash them out with a hammer. you will need access to a press but it is the best way IMHO. Boring out the guide is OK if you can set it all up very acuratly with the piller drill but you risk damaging the bore that the guide fits into which will right off the head if you can't get oversize guides.
