Crankshaft..
need4speed
Crankshaft..
Post by need4speed »
What is the ball-park figure for balancing a crank these days...tried getting a hold of shaun (V8D) earlier but he was not available....Thought id ask here to save his time..
russell_ram
Post by russell_ram »
Typical 'production' crank balance figure is < 10 gcm with the correct equivalent masses on the rod pins. Actually, production balance machines do the 'equivalent mass thing' in the software and only ever balance to a nominal set of pistons and rods. Any decent balancing outfit will do better than that on a one off basis.
Just re-read the question and now think you're asking how many pounds (money) - doh !
Russ
need4speed
Yep i was talking about cost..lol
I read what you said with interest though...
Post by CastleMGBV8 »
Need4Speed
Cost of balancing the rotating parts, crank, rods, pistons, flywheel and front pulley is in the region of £150.00 for a straightforward balance to £250.00 if the addition of heavy metal is required, this is by Real Steel but they are backed up for at least six weeks. The same specs at Serdi also in Uxbridge is £350.00/£500.00! only 1-2 weeks wait.
Ther are not many people in the south that seem to do V8's but if your nearer the Midlands you probably have more choice.
Kevin
need4speed
Thanks for the information Kevin.. :wink:
Serdi are not shy with those prices are they... :shock:
