Another LT77 Question...
v8trev
Post by v8trev »
What's involved in changing an electronic speedo drive to a cable speedo drive on an LT77 'box. Is it too much to hope that it's just a straight swap?.....
Looks like it should be a straight swap:
http://www.rimmerbros.co.uk/rimmer/rove ... Transducer
Obviously you need the cable, drive gear, and all the bits associated with the bearing and retaining clips as shown on the exploded diagram.
russell_ram
Post by russell_ram »
I can confirm 100% that it's a straight swap - you'll need all the bits in the Rimmers pictures - even the clamp is different.
I doubt very much if you'll get away without having to recalibrate you speedo though as the available gears only vchange the cable speed by a few % - you might be lucky though.
Russ
http://www.speedograph-richfield.com/
do corrector gearboxes so you can get the speedo working correctly.
v8trev
Post by v8trev »
Excellent as always guys. Thanks very much :)
Pocket rocket
Post by Pocket rocket »
Does that mean that you will have an electronic speedo sender going spare? :)
TVRleigh
Post by TVRleigh »
I'll do you a swap for a manual one for an electronic one.
I don't seem to have the clip that holds it in, also I don't have the cable.
Current V8 car TVR 400SE 240 BHP
Current Project TVR Tasmin Race, with 3.9 running at 230 BHP
Currently building a 4.6 300 BHP Xbolted Engine for it. Solid Lifters and Group A rockers, Stange 4 heads, Pocketed piston, fully balanced.
