Injector Calcs.
still never came to an answer lol.
what to set the base pulsewidth too :oops:
and just got this mail through from USPS,
Label/Receipt Number: xxxxxxxxxxxxx
Status: Out of Foreign Customs
Your item cleared customs in GREAT BRITAIN at 7:53 PM on February 8, 2008. Information, if available, is updated every evening. Please check again later.
my injectors are in the UK :twisted:
dnb
Post by dnb »
7.22 ms will be fine for reqfuel. Unless you used the divide it by 2 and double the VE table trick.
never done that one mate, :oops:
im going with 7.22,
i gather the ve table will stay as is for now until we do another datalog yeah?
do the injector times need changing?
dnb
Post by dnb »
Yes, the VE table should stay the same for the next datalog.
The injector times will need changing, but wait until the transient diode mod is done because this vastly changes the injector times. We can use the VE table to cope with the different injectors in the meantime.
you got the part number mate? as will look into getting a diode then for my ecu then its all done ready to go
dnb
Post by dnb »
Yes.... somewhere!
I'll post it here when I find it, otherwise I'm sure it's on the VEMS forum somewhere.
got home from work to a nice parcel from the states,
i am now the owner of a set of bosch green injectors,
That was quick !!!!!
ordered them 7pm our time Tuesday,
cleared uk customs 3 days later on Friday at 7.55 pm,
arrived my front door today,
how about that. try getting something that quick in the UK.
they came from www.fiveomotorsport.com if anyone is interested.
if im correct thats my layout mate,
checked for the diode £20+ on vems shop
got a number i'll see if maplins is cheaper.[/img]
just a thought,
whats the best way to fit the new seals on the injectors into the injector manifold bores and fuel rail?
smear bit vaseline? or similar?
bit of oil, or spray silicone grease etc
ta stevie.
i see the paint is still as thin on new injectors as is on the old ones,
the black paint on the bosch ones seam very thin, and will rust like the old ones are doing where the car is left in the garage over the damp winter,
you recon be ok to give em a coat of smoothrite etc to try and keep them looking new for a bit longer :?:
