what is the best and cheapest way to do this.
thanks in advance
Andy
The 35d8 belongs the early front cover so using a newer electronic distributor will need the newer front cover. A luminition kit is probably the easiest way to convert this setup to electronic. It isn't what I would call cheap though at around £140. If you were to change the front cover and dizzy it could cost less and you would get a better oil pump in the bargain but it is more work.ChrisJC wrote:Grab a matching coil / distributor from a Range Rover, preferably amp-on-distributor-body type. Then the coil +ve just needs an unballasted 12V supply, and the coil -ve will drive the rev counter.
