RV8 powered T25 Panel van
Danny-Boy
Post by Danny-Boy »
Hello all, new to the site looks like i`ve got a lot of reading to do. The plan is to put the recently aquired rv8 from an ex-police van into my vw panel van. Am slowly gathering all the parts required just waiting for my adpter to turn up from the U.S
Danny
It`s mine and i`ll wash it as fast as i like.
Hi Danny and welcome to the forum mate,
I took the V8 from an ex-police van and stuck it in a different van.
http://www.cowdery.org.uk/fittingv8.php
OK, I fitted it into a smaller version of the same van and fitted EFi to the engine too, but you can get an idea from the pics what's involved......
Good luck!
Danny-Boy
Post by Danny-Boy »
Thanks for the welcome gents, I have a good deal of plumbing to do on my van yet as it was previously aircooled but am getting all parts from a T25 diesel pick-up, water pipes radiator heater matrix ect. I have had nothing to with V8`s in the past so it`s a learning curve me. I have lots of stupid newbee questions, such as there seems to be a highly eroded pipe that runs from each head back into the old airbox,these pipes are wrecked and just fall aprt,do i need to replace them or can i just blank them up??, If this is a daft question then appologies, :oops:
Danny
Post by ian.stewart »
Hi and welcome, just seen this on U tube,
Made me smile.----------------- http://uk.youtube.com/watch?v=EWLFGPl1Kdk
and this is even better.------
http://uk.youtube.com/watch?v=4SW8CmgcfmE
THE SMOKING GNU
Danny-Boy
Post by Danny-Boy »
I did contemplate the flat 6 route but funds do not allow such extravigance, plus i love the V8 burble.
This is the kind of thing i`m after.
http://uk.youtube.com/watch?v=3BiELRhUelg
Danny
chrismc
Post by chrismc »
I can understand that! :lol:
Probably need some pics of this corroded pipe. Sounds like some emissions stuff which can all be blanked off, but it might be a breather which needs fixing!
Danny-Boy
Post by Danny-Boy »
I think that it is emmisions gubbins, there are 4 small pipes that are tapped into the heads beside each plug socket,and converge into a largerer pipe which was at one point had rubber hose going to the air box.
If they can be blocked off any suggestions on best method?
Danny
Definitely is emissions stuff from your description.
I would take out the piece that screws into the head, weld it up, and screw it back in.
Danny-Boy
Post by Danny-Boy »
Thanks for your replies, will get them welded up.
Danny
bodger
Post by bodger »
it's a system called "PULSEAIR" , it was fitted to ldv v8's but only the ones with solex carbs
it's used to bleed air into the exhaust port which is to dilute the exhaust gases and reduce emmisions .. they now fit it to a lot of big bike engines and quite a lot of cars ...it's the same type of system that is fitted to ford zetecs too
probably the easiest way is to tap the holes in the head and screw a bolt in ....thats what i did on my Hayabusa
= http://forum.landrovernet.com/archive/i ... 11927.html
