No power to pump!!!
Dannyb
No power to pump!!!
Post by Dannyb »
After previous post regarding non starting everything has been checked fuel pump is working but no power to it does not prime up no voltage to it at all? Checked spark and wire from coil to ecu is ok can hear fuel and ecu relays click on changed fuel one anyway. Also tried spare ecu
Anything else? just going outside to check the inertia sitch
Dannyb
Post by Dannyb »
Bypassed inertia still no joy , However if i hotwire fuel pump it runs fine? How many lives should there be to fuel pump relay i have one?
Have you gt a multi meter?
Test the out from the relay to see if it is actually supplying power
If it is try another wire connecting the relay to pump.
It it works then there is a break in your original wire.
Dannyb
Post by Dannyb »
Also am i going to fry something hotwiring
Dannyb
Post by Dannyb »
There is power 12v to the relay but there is no other wires live?
ramon alban
Post by ramon alban »
Dannyb wrote:There is power 12v to the relay but there is no other wires live?
Check out the steering module.
http://www.vintagemodelairplane.com/pag ... ule01.html
in conjunction with this cct
http://www.vintagemodelairplane.com/pag ... cuit01.pdf
