LT77 gear lever position
v8trev
Post by v8trev »
The Sd1 type remote/extension, as you all know, places the gear stick too far back between the seats when used in most conversions. Other than shaping the stick to bring it further forward are there any other bolt on solutions?
Ta
demo2
Moderator Gold
Moderator Gold
Post by demo2 »
Do like i did mate, cut and shut the extention, just need sumeone wiv an ally welder :D
The LT77 remote from a Sherpa van is much shorter. I believe the remote from a Jag is too.
chrismc
Post by chrismc »
The Sherpa remote is approx 7" shorter than the standard SD1 remote and bolts straight on. The problem is they are pretty rare these days.
One went on ebay for £130 just before christmas!...... :o
Probably a better bet (and cheaper) to shorten your existing one like this guy?
http://www.vord.net/cars/mgb_mods/gearb ... nsion.html
Cheers Chris :)
v8trev
Post by v8trev »
That's excellent guys. Thanks for the info - had thought about cutting and shutting the extension but hadn't really looked into how to do it - as I'm working to a fairly tight budget that'll probably be the way I go.
v8trev
