Oil Filters
Oil Filters
Should be an easy one, What is the shortest oil filter that can be fitted to the SDi pump???? I seem to remember I used a Renault 5 on something, could have been a Rover?
THE SMOKING GNU
I have this vague recollection that I fitted a Sierra Cosworth filter to mine in about 1993. Can't quite be sure which flavour though. It was about 2 inches deep.
I just visited the motor factors and asked for the shortest one they had with the same threads.
v8alex
- Helpful or Confused
I know you can fit a Cosworth filter. Pretty sure you can use Renault 5 too as I remember someone saying once that they did. In fact, many filters do have the same thread size. I have a pretty short filter made by Coopers - will measure it tonight and let you know the part number too if I can find it.
Alex
Alex
v6 essex capri use a short filter and it fits SD1,
i have used them on my capri before when using an oil plate to give clearance.
- Nick Moore
